查看: 3731|回复: 10
[技术交流] 循环冷却水系统初步安全分析报告
发表于 2011-2-24 20:02:51 | 显示全部楼层 |阅读模式
发表于 2011-9-29 19:01:27 | 显示全部楼层
呃,期待更多点儿的资料哦
或者lz联系我哦,water.wangsir@yahoo.com.cn
相互交流资料~
发表于 2011-10-14 08:10:04 | 显示全部楼层
要是有个内容提要就更好了,感谢楼主!
 楼主| 发表于 2011-10-14 12:22:51 | 显示全部楼层
回复 3# njustxj
Main cooling water system (or called circulating water system) during the units are in operating will provide cooled water to the condensers of the turbo-unite and the heat exchangers of the closed cooling water system(SRI) of the conventional island, is for remove the after-heat. The water source of the main cooling water system shall being the sea water.
The main cooling water system shall be consisted mainly of outer diversion works out site (This part could be worked out after finished the conceptual design stage is about in September 1998), forebay on site, intake structures on site, water supply tunnel on site (C.B), rubbish cleaning equipment (drum-type filters), circulating water pumps, inlet pipe and valve of condenser, condensers, outlet pipe and valve and condenser, syphon well, water discharge structure (attached drawing 10.4.5 could worked out after finished the conceptual design is about in September 1998).
 楼主| 发表于 2011-10-14 12:24:03 | 显示全部楼层
回复 2# water.wangsir
CONTENT
10.4.5 Main cooling water system (PA)        1
10.4.5.1 briefing        1
10.4.5.2 Design base        1
a. Safety design base        1
b. Power generation design base        1
c. Codes and standards        1
d. Hydrologic parameters        3
10.4.5.3 System description        4
a. Briefing        4
b. The main equipment        4
c. System operation        4
10.4.5.4 Safety evaluation        4
a. Outer water intake installation.        4
b. Forebay of on site        4
c. Water intake structures        6
d. Water supply tunnel of main cooling water        6
10.4.5.5 Tests and inspections        9
10.4.5.6 Instruments and control        9
发表于 2011-10-15 21:59:43 | 显示全部楼层
下载学习,
发表于 2011-10-16 09:50:42 | 显示全部楼层
so that .....
 楼主| 发表于 2013-9-8 13:18:41 | 显示全部楼层
回复 1# yinmahe
发表于 2015-9-25 12:19:06 | 显示全部楼层
谢谢楼主分享
 楼主| 发表于 2022-11-5 05:23:55 | 显示全部楼层
值得学习参考
GMT+8, 2024-4-26 21:19 , Processed in 0.225316 second(s), 33 queries .
