1、Extrapolation of XFOIL generated or imported polar data to 360° AoA
2、Blade design and optimization, including 3D visualization, using XFOIL generated or imported profiles
3、Turbine definition (rotor blade, turbine control, generator type, losses...)
4、Computation of rotor performance over lambda (tip speed ratio) range
5、Computation of turbine performance over wind speed range
6、Annual yield computation with WEIBULL distribution
7、Manual selection of BEM correction algorithms
8、Manual selection of all simulation parameters
9、Data browsing and visualization as post processing
10、Export functionality for all created simulation data
11、Blade geometry export functionality
12、Storing of projects, rotors, turbines and simulations in a runtime database |
