部分中英文对照
部分中英文对照
亚临界压力锅炉: subcritical pressure boiler 0 I  [2 M7 j' x% J) T- e' s
临界压力锅炉supercritical pressure boiler
; \4 I" n" D) }5 v# u超高压锅炉super-high pressure boiler
8 q% o+ E* i$ X8 _1 }0 y蒸汽锅炉 steam boiler' B, R! I: u! S8 e2 z' |+ J  w
蒸汽发生器,steam generator
7 `% T6 s  W' {液态排渣锅炉wet bottom boiler , ?  r" A+ z0 f3 H
固态排渣锅炉,dry         bottom boiler
% o, a! g+ s' M& b, N3 Z9 S2 F燃煤锅炉   coal-fired boiler4 N! d0 X3 u2 `4 Q$ L! Z6 J2 s7 }
燃气锅炉    gas-fired boiler
, x4 f- V. m) |$ N; \& g# N1 u燃油锅炉oil-fired boiler * i+ Q' {- q! i+ H+ C6 e8 [! r0 \6 @2 j
# l: I  C+ k% Q: |# l4 l自然循环锅炉 natural circulation boiler9 g$ [4 O4 z( v( F6 e# \0 p
汽包锅筒锅炉drum boiler 0 r; q# b. V% r$ K! E" l
强制循环锅炉,controlled circulation boiler
0 h5 {0 k# R5 M# \1 x直流锅炉 once-through boiler
0 t# M" z) \( L9 n8 G6 V# r* R复合循环锅炉,combined circulation boiler - ^& D) y- h; ^
旋风炉,cyclone furnace boiler
! L4 O) P0 b0 d沸腾炉 fluidized bed combustion (FBC)boiler
2 G: E; ^& z' ?# B! N循环硫化床 circulation fluidized bed combustion boiler( n, z" K1 \0 t: W5 _9 e
增压循环硫化床锅炉 pressurized circulation fluidized bed boiler
$ N+ S2 ?9 r9 n5 J7 u+ M6 {链条锅炉 chain-grate boiler $ E2 ?/ B  c/ A* o1 l% c. D2 H9 z
热水锅炉 hot-water boiler ! ^+ K7 q& F: X, p1 A2 e  s
废热(余热)锅炉 water-heat  boiler 。 heat recover steam generator (HRSG)
8 V# Q! Y4 C; V, ]" ?/ D( |7 E7 r启动锅炉     start-up boiler + Q1 m6 D- v+ O. w) A. [
厂用锅炉    auxiliary boiler) o( P0 Z8 n, w
垃圾焚烧锅炉 rufuse-fired boiler
" r, M6 \. W% b露天锅炉  out-door boiler- U2 L) O  Y* m: I/ Q
单炉膛锅炉 single  furnace boiler
' m1 z, |1 P$ \$ w4 s* v双炉锅炉 twin-furnace boiler
1 v: w0 H- f: b) c% A/ aW-火焰锅炉 W – flame boiler vertial-fired boiler
' j9 a  [0 b# S7 eL火焰锅炉L FLAME boiler % P: b, {8 L7 B* G( ~( \" l
塔式锅炉 tower boiler 1 {) c" z9 D4 A0 c: E0 B
箱式锅炉 box-type boiler 0 N$ y: a5 t7 {! x2 a* `( G9 I% z9 ?
炉强 furnace wall % [% I9 M; O7 ]
汽包  drum
& G9 U. _9 w4 a' D7 f- N9 W封头 head
' y; `: Z+ {. k5 \% M% P汽包封头 drum end head
5 r' ^  I5 k  q' |5 g, w' ~0 F下降管 downcomer! \+ c2 [- \$ t$ h
集中下降管  centralized downcomer
3 V3 m3 i: x5 c4 p6 }分散下降管 distributed  downcomer
# ~& x6 m7 Y' `8 l  j  I0 }1 _上升管  riser
4 J5 c7 y" J3 q  [4 V  G. z3 N管束  tube bundle  F$ h; y. t9 z5 S/ l) z
管屏  tube platen & w4 A$ d( m: q6 _. [, C9 ^
省煤器管   economizer tube ; J- m% L+ r$ s8 |3 F1 z7 x8 ^
过热器管 superheater tube
. W* p& R9 J2 b: k7 Y! s再热器管  reheater tube* J/ K. x0 Y! |, t0 n: s, r7 Z
蛇形管  coil ' R. n* E- [& n/ ?
吊挂管   supporting tube" n$ P0 d- B% V( z* t
引 入管 inlet pipe9 k8 s5 N/ @3 d1 A8 ?, Q
引出管  outlet pipe , y, U. k# }% ~+ ]
上锅筒  steam drum # J3 `! h- `9 V6 [5 M
下锅筒   water drum - m- {: K" N# b& H) F' q
锅壳      shell
! z0 z$ i" Y& g锅筒内部装置  drum internals
$ [/ A9 o" N. p! a" m1 l& n清洗装置     steam washer+ ^" ]5 e* {' w, G! \
上水   filling
; F, }3 c  n# m% S; K& Q水位 water level 9 s% q, W9 C8 K+ N- b; d
点火水位  initial water  level
* ?8 D% L4 t. ?* I7 k% f5 _; {. K吹扫 purge / E! b! u" S! \' X
烘炉  drying-out
7 {: `) N* s: P8 F2 P& X8 i吹管 steam-line blowing* L* S8 m5 E; }5 @. w3 R- |+ Q9 Y
钝化  passivating8 Q/ \  s( A8 t! @
集汽管  dry pipe * E5 [' K# s; C# n
蒸发受热面 evaporating heating surface
/ p* q9 I# M7 {, D' Z双面水冷壁 Division water-colded  wall " O$ K) ?( f5 x( E3 z( ~
防焦箱  anti-clinker box
/ g* `; F9 ^# z- u0 v. h锅炉管束 boiler convection tube bank
9 x: b% m6 P2 S悬吊式锅炉构架  top-supported structure by hangers
4 `& ^, v5 N, ?- L9 }6 K1 c支撑式锅炉构架  top-supported stucture by beams
( L5 R* G+ S- L2 g2 S) m刚性梁  buckstay        . G( [1 c. {4 w2 m
安全阀  safety valve
- p6 V! J2 f, g锅炉汽水系统 boiler  steam and water circuit4 y6 ~) n4 }: d" N' L' a. g7 h
锅炉范围内管道 boiler internal piping   c6 j$ C3 F( B. K7 Z
气体(化学)未完全燃烧热损失heat loss due to unburned gases5 \7 [, ?  [, \$ s* {
固体(机械)未完全燃烧热损失heat loss due to unburned carbon in refuse
& ?' h6 L( B7 _散热损失 heat loss due to radiation
! G% J! X! G9 Y" [3 H% y% q5 }: E回火 flashback
# S5 _! L% b- e$ G脱火 blow off
& d( o+ U* e# _5 ?/ f熄火 loss of ignition
% b* \! M: B9 ^( E% o+ y# S! n炉膛爆炸furnace explosion
1 _( ^( f- t: X3 m8 X5 Q炉膛内爆 furnace implosion
; W2 g9 B% J. R4 N顶棚 ceiling
: a; `1 c* c. F( I' z) {汽包事故放水阀 emergency drum drain valve
0 H% a6 r) h  d1 U事故喷水阀 emergency  water spray valve
" ]! [5 S8 H; ^7 u; W检查孔 inspection hole
8 \* ?" \' V, V防爆门 explosion vent 4 {2 A$ v! ~, F1 L7 U( A
通风界截面比percentage of air space6 E* A# R# n  B) [( Y
爆炸界限  explosion mixture limits
5 u4 S2 z8 r' x煤粉细度fineness
& }  n  O1 S+ ?5 d省煤器沸腾率 percentage of economizer evaporation( H/ b1 I9 d! s* X" j0 D% v
风室 air compartment
+ E/ a6 `, G  l% [$ \. g$ F( S多空板 perforated  distribution plate . L# s- t1 {& U0 W3 ~( s3 o
并汽 bring a boiler on to the line " k2 z+ `7 _, U# r1 `* M3 T
清洗装置 steam washer
# H. _% S5 f: V飞灰复燃装置 reinjection  system 3 ]: r8 [' a1 z* u: w: D- z
缝隙挡板 baffle plate
) G2 l+ H5 _/ i, A8 j8 D, p3 m减温器 desuperheater6 E/ t. Z. l: S
抛煤机  spreader stoker
, l) B' O1 j7 j) W6 |. K往复炉排 inclined reciprocating grate 3 X7 o: g$ E( v( N* k4 R
横梁式炉排 bar grate stoker 3 F+ r/ A' m  t- b+ D
鳞片式炉排 Louvre stoker
4 s6 \0 o0 W. |( E* v  h锅炉汽水系统  boiler steam and water circuit
% ?. l4 Q2 D3 C锅炉支架   boiler structure
/ `' g' f2 _3 I) Y0 ?除渣设备  slag removal equipment2 @; Q! J3 [+ N
吹灰器     soot blower
% o, s2 R" B- b/ Q2 N+ B水压测试  hydrostatic test
3 Q; P' ?* r+ a2 P0 M3 b验证性 水压测试 hydrostatic deformation test$ K/ i0 |) r0 x2 r
机械携带  mechanical carryover
' ?0 M0 ]. G+ _) n9 ~- z6 P选择性携带  selective carryover
# _9 h7 T5 t% F' G7 D. [- D# c零排污  zero blowdown ,zero discharge 0 T9 @6 C( u  j' N+ O  P
运行周期 cycle length/ N4 n2 }& K( m$ W1 |
纯度 purity- f# J6 p" {  y" e9 Z. X7 v8 O
老化 ageing
2 j5 g. Y$ N# f焊接  welding
- C: i8 E; m. J9 ^焊接技能 welding technique2 N& Q- @7 {, P
焊接方法  welding process
. I" _: A, x8 C. [! h焊接工艺  welding procedure
3 l, Z) }  `, r( I) g焊接工艺规范 welding procedure specifications
! e! j: r) D( C6 E焊接操作 welding operation1 X3 k$ n/ r, p
焊接顺序   welding sequence
2 p% h. ^5 |  W& B0 K6 T! l焊接方向   process of welding
7 s- r' X+ l; y* ]/ Q焊接回路   welding circuit
; M) z& ^& Y6 X& F坡口 groove 8 ]- Y  e$ r- X6 k- g
开坡口 beveling (of the edge)、
* U) q& V+ ]& h) |5 p单面坡口 single groove! V2 H' m/ F- G4 H
双面坡口 double groove 0 g0 ?$ O6 p( H/ |6 ~
坡口角度  groove angle
( H- M7 n, N. J) L$ y" w坡口面角度 bevel  angle ,angle of prepreparation
9 C% g$ T4 p' k' K) U+ a3 z: a6 e5 K接头根部  root of joint
/ T3 }7 f9 A* I3 P/ ^根部间隙 root opening
1 ]( R  e' G% I1 l$ `根部半径 groove radius6 ?, ]' k2 u* K9 d) @9 g) N, _
钝边    root face
) O; _1 c+ e8 U7 ~7 ^6 h! P接头   joint
7 v. c; A# Q0 s/ f. p/ L7 f接头设计  joint design % O- `. B" I6 Z& M/ D4 |9 v* Y9 ^) y
& e7 {" O5 y& ^7 k) }- O
接焊缝 butt weld
5 H% a3 \) s- [角焊缝   fillet weld
! K6 l+ A# K. `$ M" N正面角焊缝 fillet weld in normal shear4 |& m1 X& i2 H1 @9 ]& y9 e4 @/ u
5 Y3 `! w! y+ I冲管 flushing
& v; g+ B$ r/ x% N7 y钝化 passivating
4 t2 q: K9 n' x  ~& b5 Z6 r% j) W9 ]" f碱煮炉  boiling-out
0 t; m% h. i6 M$ G, l化学清洗 chemical cleaning / l3 ~4 j+ a* M+ J
停炉保护 storage
0 w( ^! [% }/ Z+ P1 j. t压火 banking fire
/ U( G7 k9 K! p: }! H9 k停用 out of service
, K# X$ g9 X0 B. `- i8 N停炉 outage * v1 P' S# g" l: f& d
Shutdown
* D9 q5 A( o/ \# F启动流量 start-up flow rate ' m5 S$ |  }1 y3 g/ s% o
启动压力  start-up pressure 6 Z* f2 _* T' ?' C$ y
并汽 bring the boiler on to the line
( D' p4 i1 ^" t2 o0 G放水 blow off - K2 b' S! `( N7 p" W/ X( v( v' E/ T
吹扫 purge7 S+ J$ b# a% b8 w$ l
' h# @' k  s# F% }4 E上水 filling
$ C  l5 X( z! }. l' \热流计 heat flux meter9 `4 E. X, A. b$ T7 B9 t3 e2 W
高温腐蚀 high temperature corrosion+ i5 K. x0 y0 e% O/ D" q
结垢腐蚀 deposit corrosion
( \2 O( w4 S& \0 p' C8 M. M$ x# u7 k" Z0 p, n, B
炉膛负压furnace draft9 B* n; Y* E3 x! B
飞灰磨损 fly ash erosion/ h# V% i4 F; x' B
单位蒸量 specific  evaporation
7 ^+ |, x( K- @# [) |) z' ^/ W煤灰细度  dust fitness
$ y: H  L' ]: F. s. I$ M$ S( `6 {法兰加热 flange heating
4 O8 L( ?' k! l$ w: E0 _1 L螺栓加热 bolt eating( w; ^0 d+ t$ F! w1 x
漏气 steam   leakage : L9 Y; ~2 j3 j0 }# H& Q) p
漏水 water        leakage
9 S$ H  Y2 j' n( Z炭精轴封 carbon packing
! P4 t8 ]/ ?7 h, h6 L无蒸汽运行 non-steam operation
( v  o% u# i9 P2 l9 n. f轴封供汽 steam supply for shaft sealing
$ S  A) U  B. [/ l7 V% z4 k8 f5 p汽封套 seal bushing  Y4 b0 ^6 i6 B# A3 ^
汽封块 seal block
- U; u* X1 g6 E; }6 Q7 O+ ~  v汽封齿   seal tooth
1 K; q2 O' d6 \轴承支架 bearing stoll  bearing bracket) A2 X. J: [& {2 [
拉筋 lacing wire
4 Q( Z+ z5 }) J9 q5 U平衡块balance weight - H5 ]* P: i: b" r
固定螺钉 dowel5 `) m- G9 q& g( x: a+ t4 \1 a" @
清水池 cleaning water pond " L& w. {* }  g, k5 C: F- r7 N
布袋除尘器 bag house ,fabric filter0 t4 w! ?- H* @
回收水池 water recovery pond" e4 u2 ~/ Z& F8 n: ]4 G
灰浆泵 ash slurry pump
" N- V. t. ?/ Y! J: e7 J$ _# \灰渣泵  slag pump ; ^; `) R! Y$ ?/ H4 ?
酸洗  acid cleaning , c0 Y5 ^) h- X- a
绕度 deflection
" X1 o1 E0 K8 u, {' }$ z2 Z台板 sole plate
& ]1 k, R* A! N3 {0 ^. G! ]% V弹簧吊架 spring hanger
# x. n' e% ^+ B( t; i) v2 _. E汽机房行车 turbine hall overhead crane$ z4 Z7 D: O+ e, P6 v# p( m
主汽门 main steam stop valve 4 ?' I0 P: [' x- K2 K! p
旁路装置 bypass device
1 I) d' i6 p1 s3 I. R  t4 O汽机底座 turbine pedestal% g4 X' ?7 w0 J5 e3 H+ m, Y/ `" _
穿墙套管 wall-through bushing
# S; @% v, y! f, z' ~7 V( i# a, c! V! h$ K- r. c
供电 power supplying
- L5 W# y  w- q, T/ I; X超临界锅炉 supercritical pressure boiler
, d0 D/ k5 \  s挡风板     air baffle plate
, Q, u" c% ]* h0 C空压机  air compressor . _! I3 z; d% M  _; e; P
空气冷却器 air cooling tower
+ A* k. Z/ l/ C. C风道  air duct
' r9 O, e, O) I# W6 e空气过滤器  air filter ! D, B7 J# f6 o# a& ?  U" ?: Y4 Q
空冷汽轮机组  air cooling turbine unit
2 `- g8 [+ ~, H平衡管 balance  pipe / p9 l6 |8 s" _8 Y1 P  h
平衡块    balance weight
, X, }7 H1 J2 P) X0 P- F0 R皮带给煤机   belt coal feeder
" j) g& c3 Y0 [4 N4 \1 V1 S( p" d酸值   acid value 7 K5 o& U9 u# \& F
酸洗 acid cleaning ,pickling - b$ X0 j% ^' H$ n! P7 G$ ?
合金 alloy 6 i" ?5 I3 t9 _
合金钢 alloy steel
6 G5 \# C. ]; A, \0 ], X9 S% O9 D防腐 anti-corrosion
8 @4 e! I" \) d防爆 anti-explosion ) T) I) Z; r' b7 E
防腐漆 anticorrosive lacquer
& s# L, |0 G6 n1 [& S弧段 arc section
" q1 E9 S' A; a# H% p灰 ash
5 M* C3 ^% z8 s$ v: j积灰 ash deposits # d3 d3 D, s# ^. R
堵灰 ash fouling
- u* u7 }9 i8 A除灰系统图  ash  handing system  diagram
: D+ x( l! E, c9 v% J灰斗 ash hopper
) E& A) M9 Q4 K2 Z4 [除灰管道 ash piping . L( J; [# ^; A
灰渣泵 slag pump
  t6 a3 ]2 T+ }- [: g5 C灰库   ash silo
! M& g/ K' U- x! i: q! u8 V灰浆泵 ash slurry pump 3 e: U1 [& c7 Y: n) a( T
灰软化温度 ash softening temperature 2 C/ G9 v6 L3 b6 G2 B6 X. B0 i# P# u
灰厂 ash yard
4 \+ P, `3 g6 _! z$ N灰坝 ash yard bam * X4 i2 P1 z: p& d/ }& k3 I
厂用锅炉 auxiliary boiler 4 @5 z  J) q1 [3 X* a. Y) E9 A
堆焊 bead welding) m; H6 h3 F$ j
灰浆 池 ash slurry pond
% [, U* ~- y9 t8 Z1 D- e; b7 h锅炉房 boiler hall
6 F" f9 U/ g6 m, F, d) a6 |$ \/ e停炉 boiler shutdown
+ n# ?7 X1 ^8 S- q6 w; j锅炉机组 boiler unit
* e, b3 v+ C8 @- V  ?锅炉热力计算  boiler thermodynamic calculation
: }( n" u5 B/ N+ b9 v& j' y锅炉水循环 boiler water circulation
+ j6 I( W/ q% v6 q$ r) X锅炉上水 boiler water filling : V7 o" T. j% K) P% ]! G
找正 centering % P& }3 L, `; L% m& L3 J* T) V
顶棚 ceiling
! L) V& G# a8 E; M+ E# }' E' l检查性试验 check-up test
5 j6 G1 n; T1 @  a加药泵 chemical feed pump
# N) \3 J1 S  J; H8 |& u' a/ g压型钢板 channeled steel plate
6 v. W/ s  w, U输煤综合楼  coal handing complex building 6 A: a0 e3 q+ ]$ b' h4 `
倒煤槽 coal guide trough
6 p2 l, G( H6 H' k* s) M8 ^输煤机 coal conveyer3 s. R+ ~3 F1 R: e& h$ c  X
碎煤机 coal crusher - \- m! q& U% K
煤耗率 coal consumption rate ) z1 w% A+ X8 v6 z
堵煤 coal jamming
; R2 s% K. N' c  \储煤场 coal yard
6 g: i6 q$ x3 _7 H煤场排水沟 coal yard drainage cannel 5 R" `4 b# u+ k  i: D3 h" V
粗灰 coarse ash 8 H" n; {# ]( P0 g
代码 code number
5 f$ L9 Y9 |8 K1 `蛇型冷却管 coil cooling pipe & B# }9 s0 @6 g: ?$ Y
冷紧 cold spring 5 O0 h) L  c  R* X5 h* g
燃烧室 combustion chamber
& i- q) l2 ~9 B) L& x- q9 n混合联箱 mixing header9 l% H4 @' l- d4 a; Y
分配联箱 distribution header
  q, G# B1 Z- j  @# D* F! t) d- S支撑箱 support tube
- s. N+ ?, m) X5 ]% x: A' C连接箱 connecting tube : b2 U! @1 {  \8 @' w( f
点火油枪 ignition oil torch             / h6 J+ ^7 I  A. E2 I) t4 u
水冷壁 water wall
( N. H7 F$ B  m" u2 i燃烧器 burner 0 \2 V& D* R# K, F
过热器 superheater
, `4 _4 v! R8 O7 y- c0 ^再热器 reheater - e& G# C7 w% D% ]
- J0 h9 d3 r9 p
减温器 attemperator
$ O* ]; W: Z3 d4 ~4 L上升管 riser 2 H9 O$ A6 _1 B. `
boiler and  auxiliaries
' c3 B9 A8 N+ M1 ^# {爆管 tube brust
, }. v' a8 V( l; A9 x1 v( F( _* e, G给煤机 coal feeder   S3 Q* s+ K( N& [, l3 C
堵煤 coal jamming" Q7 y6 y* A$ S$ A0 ^
积粉 pulverized coal deposits) G- D% s' L7 D6 O( \  D' K( e
风机跳闸 tripping of draft fans / O8 {( z/ u, A- W" s
炉膛熄火 fire-off in the furnace : ], a  u8 X) D$ D- E! Y
炉膛压力高 high pressure in the furnace
$ A& u- J2 Q9 f* F( D汽包水位过低 too low  drum water level + ^  N) q9 r1 w* V9 V6 F) k: d% H
磨煤机 coal pulverizer
; X4 z. k( w( O/ g重油泵 heavy oil pump
& B% b' l. z1 W锅炉冲管 boiler blow out 0 b' m3 r2 u4 x
锅炉酸洗方法 boiler acid cleanning approach
* V4 L/ l! z6 q3 H! n2 g, ~厂用锅炉 auxiliary boiler 2 Z7 i' b9 [- F( |6 E' B8 h
化学加药和取样系统 chemical feed and sampling syetem 4 v/ P' u+ m0 `( W6 S
压力部件 pressure part
$ M. @# }* @$ l8 T火焰监视器 flame nomitor
% w9 B" y8 i) c2 Z& U* @锅炉水位计 boiler water level guage& p: J5 Y1 O/ E! N
烟气再循环 flue gas recirculation2 i9 k- U' q6 D/ P" _4 C
护板 lagging " H# M1 s0 n- ]5 g4 ^
动力控制阀 power control valve
- M4 [, y* Q4 T( e- c$ ^) A+ [平台和扶梯 platform and stairs 2 J- P  [& R- {6 `2 }* P
吹灰器 soot blower
0 [& H! @3 U7 q内厂用水系统 service water system in  main building8 S- \$ r: F" ^3 q2 O  y
厂用和仪表用压缩空气系统 station and instrument compressed air system
- D- }" p3 W- L# }+ t8 P5 F辅助蒸汽系统 auxiliary steam system + e% n6 n4 }9 g  L/ Q* i0 e: o; u
输煤系统coal handing system / O* U; f6 Q) e5 u
除灰系统ash handing system ) R2 @  u( s: P, q& C9 @
消防系统fire fighting system
, D; w! d& d6 Y0 q油枪 oil gun
1 h8 f. ^5 K/ M2 K0 M1 I8 J水冷壁管损 damage of  water wall tube 1 V6 V1 X9 x. q. t
  ~4 ~. p$ |  m, ~9 m$ r汽包流水阀  drum drain valve 1 K$ j$ N: K* g; t4 y
粗粉分离器 classifier ( _9 E+ g2 r4 I; N4 \; _; R* [; w
堵煤 coal jamming 8 B9 e8 i- a1 Q8 ~: U0 e. z( Q/ M
锅炉! a; {# G) P  ^! L. c
酸洗 acid cleaning
- ~" B$ E# K* a& w6 \) \, f级间漏气 interstage leakage 4 ?( T$ t1 J5 J. d
原煤斗 coal bunker
4 F7 J; _" A3 M) D! ]过量空气 excess air  / ?1 v$ o) _- C3 H% h  b
转换开关 inverter
+ _' O+ L; c5 n; k4 T) {8 y) ~引风机 induced draft fan
! q( z1 v2 o2 T. h! Y相互隔离 isolate
6 p( g; N$ m' @4 b5 W0 J' i' o汽包 steam drum
* c% i8 p& L7 n& J1 t( k# d6 n元件 item
  k+ Y: B: B& m9 ?( n0 m2 B* \5 m* c低压厂用变 sub-distribution transformer : P, e/ P1 ^+ @) m' N6 N/ T+ B
支撑轴承 journal bearing
+ d* s, X$ ~! R0 R0 w主蒸汽  live  steam + k. O7 G# O: W% q- U
吊耳 lug  " A/ \6 d1 G/ \: D6 A$ ]
主要辅机 major pant item , t/ R! \) u9 Y' b
水分 moisture : O" L0 D6 W) l( @2 q+ b/ U
运行工况 operation condition   a  R5 i$ [6 {2 w: {- ]
集控室 central control room
& I3 D4 d5 V+ z停运  outage
- e' \  g9 B* b. f9 V1 r! W临界压力 critical pressure
0 C% y: J6 W$ c% o7 l营业时间 business hours ) \; n: I1 ?6 l, @! r. z) T( I& C
办公时间 office hours
$ A9 b/ m6 O& O4 I& k入口 entrance
; b# X! V; X  N- L3 u6 l7 C: W出口 exit8 I9 p/ r! f0 V1 B. X
推push
, X& b) Y2 w  b7 {拉 pull 0 v  w  W# d5 X' N
此路不通 shut
4 X1 K6 X) w7 [1 o营业 open * B, S( e# e7 N7 [7 e: b. f& d
暂停 pause & t; L' L. |; i3 j# X! q
关闭stop
% h" C, {- W) P& k8 W% z下班 closed 4 N  W, m, t! Q
菜单 menu 2 F; s  h) W' T& i
易碎 fragile
& t; p* o, f) Y& [  r! o' X此面向上 this side up . A2 N$ w1 v) R# r; e
单行道 one street ' X, U3 \' y: B) A6 l2 s+ D
靠左右 keep left right
, s/ }$ s4 m. n只准公共汽车通过 buses only 2 F7 c- {# D' D1 g
油漆未干 wet paint
! A) `0 Q$ A+ d3 l/ @$ J" w失物招领处 lost and found
6 G) J5 J, `! [% K; P快车先行 give way   A8 ^0 h1 ~0 R0 e  n
加油站 filling  station
( ~: ?! a  Y3 U& o6 Q; H1 h+ |禁止吸烟 NO smoking
0 m! L: o& O* K% E: B0 w请勿拍照 NO  photos
* E/ H7 n8 _7 j) h& ?- r9 @游人止步 no visitors
2 f: I5 a& L! X禁止入内 No entry ! N( C. u- c: g6 F$ J" x" N6 p1 I
闲人免进 No admittance 7 m3 m, a* R: i5 O) z
Beware of pickpocket
( C' N0 J2 d1 R/ C7 E) `9 Y" {对号入座 sit by number * v  L0 O: t0 R0 u+ H3 J' p
来宾登记 visitors please register
/ K! F1 x  |8 v: e置于阴凉 in shade
0 `  n; i2 L: N- L开环 open circle 、
$ ~; w' ~. s* p/ d% k/ b0 _天然气 natural gas
- `$ ?( h1 a2 o" o8 G, k( D顶点 apex 灰分 ash$ u  ~# i& y. T( A7 h
叉形叶根 multifork root
' z1 y  ~/ j, i' t" t: B排污管 blowdown pipe, _+ g3 e, v; }5 y; B: W
成批的 batch oil
不错,资源共享,谢谢了。
呵呵,懂得不少嘛
继续往下发吧
学习了,谢谢提供
江山美女一起夺
非常感谢 楼主啊
漫漫长路
