A
Acceptance test 验收实验
Actual enthalpy drop (enthalpy rise) 实际焓降(焓增)
Actuating oil system 压力油系统
Aero-derivative gas turbine, aircraft-derivative gas turbine 航空衍生(派生)型燃气机轮
Air charging system 空气冲气系统
Air film cooling 气膜冷却
Air intake duck 进气道
Alarm and protection system 报警保护系统
Annular combustor 环行燃烧室
Annulus drag loss 环壁阻力损失
Area heat release rate 面积热强度
Aspect ratio 展弦比
Atomization 雾化
Atomized particle size 雾化细度
Automatic starting time of gas turbine 燃气机轮的自动起动时间
Auxiliary loads 辅助负荷
Availability 可用性
Average continuous running time of gas turbine 燃气机轮平均连续运行时间
Axial displacement limiting device 轴向位移保护装置
Axial flow compressor 轴流式压气机
Axial flow turbine 轴流式透平
Axial thrust 轴向推力
B
Base load rated output 基本负荷额定输出功率
Black start 黑起动
Blade 叶片
Blade 叶片
Blade height 叶(片)高(度)
Blade inlet angle (叶片)进口角
Blade outlet angle (叶片)出口角
Blade profile 叶型
Blade profile thickness 叶型厚度
Blade root 叶根
Bleed air/extraction air 抽气
Blow-off 放气
Blow-off value 放气阀
Burner outlet temperature 透平进口温度
By-pass control 旁路控制
C
Camber angle 叶型转折角
Camber line 中弧线
Can annular combustor 环管型燃烧室
Can-type combustor 分管型燃烧室
Carbon deposit 积碳
Casing 气缸
Cascade 叶栅
Catalytic combustion 催化燃烧
Center support system 定中系统
Centrifugal compressor 径流式压气机
Centripetal turbine 向心式(透平)
Choking 堵塞
Choking limit 阻塞极限
Chord 弦长
Closed-cycle 闭式循环
Cogeneration 热电联供
Cold starting 冷态起动
Combined cycle 联合循环
Combined cycle with multi-pressure level Rankine cycle 多压朗肯循环的联合循环
Combined cycle with single pressure level Rankine cycle 单压朗肯循环的联合循环
Combined supercharged boiler and gas turbine cycle 增压锅炉型联合循环
Combustion chamber 燃烧室
Combustion intensity 燃烧强度
Combustion liner/combustor can/combustor basket/flame tube 火焰筒
Combustion stability 燃烧稳定性
Combustion zone 燃烧区
Combustion efficiency 燃烧室效率
Combustion inspection 燃烧室检查
Combustion outer casing 燃烧室外壳
Combustion outlet temperature 透平进口温度
Combustion specific pressure loss 燃烧室比压力损失
Compactness factor 紧凑系数
Compressor 压气机
Compressor characteristic curves 压气机特性线
Compressor disc 压气机轮盘
Compressor input power 压气机输入功率
Compressor intake anti-icing system 压气机进气防冰系统
Compressor rotor 压气机转子
Compressor turbine 压气机透平
Compressor washing system 压气机清洗系统
Compressor wheel 压气机叶轮
Constant power operation 恒功率运行
Constant temperature operation 恒温运行
Control system 控制系统
Convection cooling 对流冷却
Cooled blade 冷却叶片
Cooling down 冷却盘车
Corrected flow 折算流量
Corrected output 折算输出功率
Corrected speed 折算转速
Corrected thermal efficiency 折算热效率
Counter flow combustor 逆流式燃烧室
Critical speed 临界转速
Critical speed of rotor 转子临界速度
Cross flame tube/inter-connector/cross fire tube/cross light tube 联烟管
confidence interval 置信区间
D
Dead band 迟缓率
Dead center 死点
Deep stall 渐进失速
Degree of reaction 反动度
Design condition 设计工况
Deviation angle 落后角
Diaphragm 隔板
Diffuser 扩压器
Dilution of rotation 旋转方向
Disc-coupled vibration 轮系振动
Disc-friction loss 轮盘摩擦损失
Dual fuel nozzle 双燃料喷嘴
Dual fuel system 双燃料系统
Dynamic balancing 动平衡
E
Electro-hydraulic control system 电液调节系统
Enclosures 罩壳
End plate 端板
Energy effectiveness 能量有效度
Equivalence ratio 当量比
Evaporative 蒸发冷却器
Excess air ratio 过量空气比
Exhaust casing(plenum)(for a turbine)/discharge casing(plenum)(for a compressor) 排气缸(室)
Exhaust duct 排气道
Exhaust gas flow 排气流量
Exhaust combustion gas turbine 外燃式燃气轮机
External loss 外损失
Extraction gas turbine/bled gas turbine 抽气式燃气轮机
G
Gas expander turbine 气体膨胀透平
Gas flow bending stress 气流弯应力
Gas fuel nozzle 气体燃料喷嘴
Gas generator 燃气发生器
Gas temperature controller 燃气温度控制器
Gas turbine 燃气轮机
Gas turbine power plant 燃气轮机动力装置
Governing system 调节系统
H
Header 联箱
Heat balance 热平衡
Heat consumption 热耗
Heat exchanger plant 换热器板
Heat exchanger tube 换热器管
Heat loss 热损失
Heat rate 热耗率
Heat recovery steam generator/HRSG 余热锅炉
Heat transfer rate of heating surface 受热表面的传热率
Heat utilization 热能利用率
Heater 加热器
Heating surface area 受热面积
High oil temperature protection device (润)滑油温过高保护装置
High pressure compressor 高压压气机
High pressure turbine 高压透平
Hollow blade 空心叶片
Hot corrosion 热腐蚀
Hot section inspection 热通道检查
Hot starting 热态起动
