【英文篇名】 Simulation and Investigation on Switching Overvoltage at DC Side of UHVDC Converter Station with Capacity of ±800 kV
【作者】 司马文霞; 庞锴; 杨庆;
【英文作者】 SIMA Wen-xia/a>; PANG Kai/a>; YANG Qing(The Key Laboratory of High Voltage Engineering and Electrical New Technology of the Ministry of Education/a>; Chongqing University/a>; Chongqing 400044/a>; China)/a>;
【作者单位】 重庆大学高电压与电工新技术教育部重点实验室;
【文献出处】 高压电器 , High Voltage Apparatus
期刊荣誉:中文核心期刊要目总览 ASPT来源刊 CJFD收录刊
【中文关键词】 特高压直流; 换流站; 操作过电压;
【英文关键词】 UHVDC; converter station; switching overvoltage;
【摘要】 根据国内外现有的资料,利用PSCAD/EMTDC软件,建立了一个较完整的换流站操作过电压计算模型,研究了有关操作和故障情况下±800 kV换流站直流侧可能出现的操作过电压。计算换流站主要设备典型故障工况时,对交流母线、直流线路、中性母线等设备可能产生的最大操作过电压水平进行了分析,还针对避雷器配置方法以及有避雷器和无避雷器时的过电压计算进行了研究。仿真计算结果表明,其有利于进一步分析特高压直流输电系统中因交直流系统故障引起的操作过电压大小以及相应绝缘水平的确定。
【英文摘要】 Insulation coordination of converter station is a main problem in the UHVDC design,which will influence safe operation of the whole DC system.According to the published literature,an EMTDC model of switching overvoltage was built via the PSCAD/EMTDC software.Then,the overvoltage at DC side of ±800 kV converter station under various operation and fault conditions was calculated,which included the maximum overvoltage on AC buses,DC lines,neutral buses,and so on.The applications of arresters in UHVDC and the o...
