摘 要
本论文是针对当前电力系统输电线路的状态评估问题进行研究的。传统的输电线路检修方法已经不能适应电力系统现代化的要求,因此,通过状态评估来分析出线路的故障状态,然后用其结果来指导输电线路正确的状态检修,对及时修复线路和保证可靠供电是十分重要和必要的。
本文介绍了电力系统输电线路状态评估的国内外现状,分析了实施输电线路状态评估的内容和步骤,提出了输电线路状态评估的相关软件及其应用情况,并且研究了输电线路各组成部分的状态评估应用。
在分析输电线路状态评估的内容时,重点介绍了实施状态评估的理论基础。在现有软件的介绍中,主要介绍了状态评估计算机辅助分析系统、智能化输电线路状态决策支持系统的设计以及电力线路的缺陷预测系统。本论文最后具体分析了状态评估技术在输电线路中的应用。
关键词:状态评估;状态检修;输电线路;缺陷预测
Abstract
The paper has studied the state maintenance of transmission line of electric power system at present. The traditional maintenance of transmission line can't meet the request with modern electric power system,so, by the state estimation, we can analyze the breakdown state of the circuit, then guide the correct state maintenance of the transmission line with its results, it is very important and essential to repair the circuit in time and supply power reliably
This paper has introduced the state estimation of transmission line in home and abroad at present and analyzed the content and step of the state estimation of transmission line of electric power system, has proposed some software and their application which are related to the state estimation of transmission line of electric power at present, and has introduced the application situation of the present methods of the state maintenance which are in the concrete equipment of the transmission line.
While analyzing the content of state estimation of transmission line of electric power, the paper has emphasized introduced the theoretical foundation that is about the state estimation of transmission line. In the introduction to the existing software, introduced the auxiliary analytical system of the computer mainly, the design of DSS , the state estimation and default forecast of electric power line. Finally, the paper has made a concrete analysis of the technology of state estimation in the application of in transmission line of electric power.
Key words:state estimation; state maintenance;transmission line of electric power;defect predicting
目 录
1 概述 1
1.1 课题的研究背景 1
1.2 电力系统输电线路设备状态评估的现状 1
1.2.1 电力系统供配电设备状态评估的国内外现状 2
1.2.2 输电线路状态评估的现状 3
1.3 电力系统开展状态评估的意义 3
1.3.1 实施状态评估的优点 3
1.3.2 输电线路实行状态评估的意义 4
2 实施输电线路状态评估的内容及其实现步骤 5
2.1 实施输电线路状态评估的内容 5
2.1.1 预测性维修 6
2.1.2 可靠性评估 6
2.1.3 输电线路在线与离线监测技术 7
2.2 实施状态评估的理论基础 8
2.2.1 先进的传感技术 8
2.2.2 信息处理技术 8
2.2.3 信息及数据传输技术 9
2.2.4 故障信号分类及判断技术 9
2.2.5 可靠性评估及寿命估计 9
2.3 实现输电线路状态评估的具体工作及其步骤 10
2.3.1 做好前期工作 10
2.3.2 输电设备状态评估原则 10
2.3.3 实现输电线路设备状态评估的步骤 11
3 状态评估相关主要理论模型例举 15
3.1 架空输电线路模糊理论算例 15
3.1.1 模糊数学简介 15
3.1.2 架空输电线路模糊理论算例 16
3.2 基于状态空间法的单回架空输电线路双态天气模型的可靠性分析 21
3.2.1 基本理论 21
3.2.2 基本方法 23
3.2.3 计算实例 24
3.3 架空输电线路基本事件状态概率计算方法 26
3.3.1 杆塔基本事件权重 26
3.3.2 绝缘子基本事件状态概率 28
3.3.3 金具基本事件状态概率 29
3.3.4 导地线基本事件状态概率 29
3.3.5 基础及接地装置基本事件状态概率 31
3.4 输电线路杆塔模型与防雷性能计算研究 32
3.4.1 概述 32
3.4.2 两种模型的基本原理 33
3.4.3 两种杆塔模型的实例仿真计算 36
4.4.4 两种模型的比较 37
3.4.5 总结 38
4 输电线路状态评估的相关软件实现 40
4.1 状态评估计算机辅助分析系统 40
4.1.1 状态分析用数据的采集 40
4.1.2 状态分析模型的建立 40
4.1.3 状态评估计算机辅助分析系统的设计 43
4.2 智能化输电线路状态决策支持系统设计 44
4.2.1 状态决策支持系统的总体结构 44
4.2.2 基于专家系统的单一诊断模块 44
4.2.3 基于神经元网络的综合诊断模块 47
4.3 电力线路的缺陷预测系统 48
5 架空输电线路状态评估系统的软件实现 50
5.1 杆塔不良状态 50
5.2 绝缘子不良状态 50
5.3 金具不良状态 52
5. 4 导地线不良状态 53
5.5 基础及接地装置 55
6 有关状态评估的思考 57
6.1 实现状态评估的关键 57
6.2 目前存在的困难 57
6.3 制约因素 58
结论 59
附表1 架空输电线路技术指标 60
(一)杆塔 60
(二)绝缘子 61
(三)导、地线 62
(四) 金 具 63
(六) 防雷设施及接地装置 64
附表2 输电线路状态评估系统子程序 66
参考文献 70
致 谢 71
外文原文 72
中文翻译 80
