SGT5-8000H
The world-class gas turbine combines the best features of the existing product lines and technology advancements. It will be the primary driver of the single-shaft SCC5-8000H combined cycle power plant, which will have an output of 530+ MW and an efficiency level exceeding 60%.
技术特征
H-class, 60% efficiency in combined cycle mode
Fast start-up and cycling capability to support intermediate load requirements
Improved turndown capability for high efficiency and low emission part-load operation
Reduced complexity as an air-cooled engine and parts leading to lower maintenance and operating costs
Advanced materials to increase firing and exhaust gas temperatures
Advanced sealing system for low leakage cooling air
Siemens Gas Turbine性能参数
总出力(MW) 340 MW
压比 19.2
排气温度 (°C/°F) 625/1,157
排气流量 (kg/s) 820 ; (lb/s) 1,808
燃气轮机排放
NOx (ppm) 25 ;CO (ppm) 10
燃气轮机尺寸
重量 (t) 440 ; 长 (m)13.2 ;高 (m) ;5.0 宽 (m) 5.0
Siemens 联合循环电厂性能
单轴SCC5-8000H
总出力(MW) 530
系统效率 (%) 60
热耗率 (kj/kWh)6,000 (Btu/kWh)5,687 |
